Motion Arm Output Cam (MAOC) physical output
Kataeb
Jan 2007
www.livelovelebanon.com
636
Kindly, I was trying to use the Motion Arm Output Cam (MAOC) instruction on a Rockwell plc, but I need to have it in a general AOI function. So, I was trying to make all the variables as inputs outputs on the AOI .
The problem is that the 4th parameter of the MAOC "Output" should refer to a physical output, but I cannot link the physical address (AB:1732_OB8:O:0) to inside the AOI . Any clues if this is possible ?
MAOC(Axis, ExecutionTarget, MotionControl, Output, Input, OutputCam, CamStartPosition, CamEndPosition, OutputCompensation, ExecutionMode, ExecutionSchedule, AxisArmPosition, CamArmPosition, Reference);
Output : a set of 32 output bits that are set or reset based on the specified Output Cam. It can be either a memory location or a physical output. (should be physical to have fast outputs control)
it looks like we cannot use a MAOC inside an AOI .
Error: maoc: Invalid instruction reference. Instruction not supported in Add-On Instruction or by controller's major revision.
acording to the AB manual logix5000 controllers motion instructions When the specified Registration Input transition satisfies the Trigger...
5,207
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
39
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
88
Bom dia, Estou com uma máquina parada algum tempo, meu servo funciona em modo manual, porém não funciona em automático. Meu equipamento e...
63
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
224
