Can 1756 enbt used as rio
bornwild
May 2010
Riyadh
429
Hey all,
we have controllogix plc with controlnet and dh+ as rio . enbt is used to communicate with other plcs and plant pcs. One of our controlnet modules is gone bad. We have only enbts as spares. Is it possible to communicate to others racks using enbt . Thanks
In general, yes, you can use a 1756-ENBT in the controller chassis and a 1756-ENBT in the remote chassis to perform the same sort of connections that you would have used 1756-CNB modules to perform on ControlNet.
You need a version of ControlLogix firmware that supports EtherNet/IP I/O connections. I don't remember exactly how far back that goes... v12 or v13, maybe ?
Ethernet lacks the redundant media, long cable runs, and ControlLogix Redundancy support that ControlNet has, but because it's fast and easy to use it has largely replaced ControlNet for many applications.
You must reconfigure the local bridge, remote bridge, and I/O module configurations in RSLogix 5000 by deleting the ControlNet connections and adding Ethernet connections. You cannot simply "change the ControlNet module to Ethernet".
I have 6 machines all configured and programmed the same....only difference is the IP.... In the RsLinx Driver Diagnostics it shows to be a CSPv4...
25
17,271
please using the usb can i assign any ip address that i want ?
151
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,034
Hey guys, I'm not super familiar with Cnet, so I'd like some insight from people with more ControlNet experience than I. We have a controllogix...
897
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of...
1,138
