Can a AB 5380 use a NTP server?
theColonel26
Feb 2014
West Michigan
785
Can a AB 5380 use a NTP server directly to keep time synced?
I have found references to NTP in the manual but nothing seems to should how to set up the PLC to use it.
Not sure if there is a direct way of fetching from an NTP on a PLC, but there is a time sync tool rockwell makes, which you can run on a server to push it's local time to the PLC.
If the local time is synced, all time get's synced.
- As Contr_conn mentioned, there's the NTP AOI, which I don't have experience with. (KB QA49644)
- Some industrial switches can take NTP and provide PTP.
- Use a 1756-TIME module
Rockwell changed the Knowledgeable search engine to a AI based search engine a couple of months ago in an effort to improve the search. Text searches work better than answer numbers now. Also as you input text into the search bar you will see suggested searches below the search bar. For example I put NTP AOI in the search and QA49644 was the top result. If you want to find a specific answer by number you need to click on the To find an answer using a previous Answer ID click on the
To find an answer using a previous Answer ID, click here link just below the search bar.
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
98
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
541
I had a comms fault between my VFD and Controller (5069-L320ERS2) that started about a month ago and happened maybe once a day to now where it...
286
Hello, Just want to share my "experience" with newly received CompactLogix 5380. It's the first time I'm going to use this one. (I've been using...
1,371
