OK but not ok
hi sorry for the delay .
After going through their manual have some what gained knowledge .
And yes we can control unidrive with this HMI .
Using this HMI I would be connecting to unidrive sp one HMI will be connected to four unidrives through rj45 cable and switch . What I'am supposed to do is to program the HMI in such a way that the operate when selects Unidrive-1 then it should display a page with 6 different RPMS , again from it the operator will select the required rpm in which he wants the pump to run . Now I am learning how to assign tags which is new to me (being fresh ) then how to alot different rpm's and how to send signal or to set the rpm to the unidrive .
Also I have doubt whether we can assign 6 different speed with singal UNI DRIVE ???
how to fix the rpm??? like 100,200,300,400,500,600 to each button ???
If anybody have worked before with this Hmi or have worked with similar software please help me to understand how it works .
