can Alias tag scope be different from base tag?
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
A program I am working with has all its tags in the controller scope. The tags that needed meaningful names for SCADA consumption were aliased. Being the OCD kind of person I tend to become when trying to understand someone else's code, I exported the tags and changed their scopes to appropriate places and imported. All the tags looks right and there were no errors . . . however... The Alias and Base tags appear to have become disconnected from each other with no other outward error.
I have tags named N119[15] for example, they are aliased to a meaningful name like Vat_3_Weight. I placed N119 into program scope and let Vat_3_Weight remain in controller scope since that is what SCADA will use.
Next, using the tag organizer I enter a value into the global tag Vat_3_Weight. That value does not show up in the program scoped base tag of N119.
I didn't think that the alias and base had to share the same scope, if true that certainly weakens the usefulness of an alias.
What have I missed here?
An alias tag can be program scope when the base tag is controller scoped.
However, you cannot have a program scoped base tag with a controller scoped alias, nor can you have a programed scoped tag alias a base tag locally scoped in another program.
Hi, I'm a little confuse with the following. I have several of these. I have a tag (flow transmitter) FIT_100 that has an alias to the Analog...
3,429
Hello everybody, Today I read some Rslogix 5000 program code, but I want to modify a tag which is a alias tag to another alias. that is change...
2,531
Hi all. From looking at the controller tags list in Logix5000, how do I look at a local I/O base tag and see what alias tags are using it...
4,590
i'm migrating rs logix 500 ladder logic to 5000. please tell me how to configure the following tags in 5000 N[N100:27]:37 N122:[N128:2]...
2,151
Gentlemen, I've got 33 of these drives that I'm installing. They're all based on generic ethernet modules so once I create them it produces the...
2,363
