Modify tag for alias issue
suboliu
Oct 2010
windsor
266
Hello everybody,
Today I read some Rslogix 5000 program code, but I want to modify a tag which is a alias tag to another alias. that is change this tag for another alias, but, tag edit window show that the alias field is gray, so can't change. I test and create another tag BB to same alias. after verified, I open BB tag edit window, It showed me that may modify and change, but why original can't modify and change.
see attach file.
I think you have a Safety PLC, (1756-L71S), if I remember correctly you may have to "unlock" the safety PLC before you can edit the tag
It is safety PLC, but it is unlocked. my question is why I can add a tag for input alias, but can't modify a tag for input alias.
Because the first one is only a sort of alias. You have actually named it right down the the physical IO word (or autogenerated an alias). The second, you actually gave a name to.
The first one has special characters not allowed in names normally.
hello
you mean that "Main_Panel_Point_IO:5:I" is special characters and auto generated? that is when add module, It will generate this word ? so can't modify? can explain more detail?
thanks
when add module, It auto generates tag Main_Panel_Point_IO:I.Date and not Main_Panel_Point_IO:5:I, Main_Panel_Point_IO:5:I tag should be programmer create tag to alias to input tag Main_Panel_Point_IO:I.Date
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
152
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
436
Hi. I'm working with a SLC 5/05 but I have no experience with it. I've been tasked with trying to figure out if it is possible to directly modify...
1,065
I am building a report screen with a SQL table display, and I want to be able to adjust the time range from which data are pulled (something I...
886
Hi, Wondering if anyone has had experience/knows how to modify the multicast address of EGD Data being produced. My PLC has Producer Id...
1,984
