GE - EGD Modify Multicast Address
linkau
Aug 2020
Newcastle
Wondering if anyone has had experience/knows how to modify the multicast address of EGD Data being produced.
My PLC has
Producer Id: 10.30.44.152
ETM : 10.30.44.152
The multicast address is 224.0.7.1 <- I am wondering if it is possible to modify this?
We have two people running EGD servers on our network and I think it may cause havoc if we are using the same IPs
Lincoln
Lincoln
Have you wiresharked this? I think that may be the multicast group address rather than the address your devices are multicasting to. Do you see any packets being sent 239.30.44.152?
Really I think I am wasting peoples time here. I need to understand how Multicast works 100% before asking questions.
That's the real issue I have.
No, you're not. Ask away.
My multicast experience is only as far as a local LAN segment. I cannot speak to mulitcasting across routers. I have 10 cameras multicasting on my LAN with an IGMP querier running to manage the groups. If you wireshark you network with the filter "igmp", you'll see all the querier messages and should be able to determine which IP addresses are group addresses and which are your servers.
I don't have a link to it since Emerson bought GE's PLC division but you need to get a copy of manual GFK2224Z PACS Ethernet Manual.
Gives you more than you want to know about multicast. If I remember correctly, the producer ID is what sets the multicast address.
You do not need to change the values of ip 224.0.7.1, as they are reserved addresses. What you need to do is keep both of them in the same group id, but each PLC must contain a unique exchange id.
Hi All, having a bit of a hard time getting EGD communications working on Emerson CPE310. SO far i'm just trying to configure 1 Exchange of...
452
I have a project where i have two rx3i plc systems seperated by fiber with fiber\ethernet media converters. Both processors are IC695CPE305. My...
1,142
Hi! I have the privilege to take over a project from a guy who didn't even bother to leave backups or proper documentation to a system. Coming...
23
5,822
When attempting to upload the hardware configuration I get the message everything was uploaded succesfully but in the message center I get this...
1,760
After reading through some older threads and checking out my old friend GFK-2224, it sounds like an RX3i CPU can talk Modbus TCP, this much I'm...
1,476
