Can Wonderware & FTView Coexist?
bludeuce
Mar 2017
Park City, KS
I have a customer that utilizes both Wonderware & FTView for different parts of their facility. They would like to have a backup PC that is capable of being inserted into either system in the event of a PC failure. I realize that the licensing will have to be addressed as well as keeping both applications up-to-date, but my bigger question is... Could both of these software packages be installed on the same PC & would they interfere with each other?
TIA
Maybe this is to simple, but could you not just virtualize either in separate VMs and then just run the one you need the day the backup PC is needed?
I have run both together before, Need a fairly beefy PC as they aren't light applications either of them.
We were connecting to different PLCs/Systems w/ them, but yeah.
Thanks Dravik! That's exactly what I was wanting to hear...
The hardware shouldn't be too big of an issue, we generally throw some pretty heavy hardware at our HMI's, to stay ahead of the curve (HMI's tend to get replaced at a much lower frequency than the office variety). They won't be running both apps at the same time anyway, it's an either/or situation.
Thanks mort81,
Virtualization is a possibility that I hadn't considered, should work, but the MSFT licensing gets a little more tricky with that solution.
Virtualize all of your SCADA servers. Keep live backups of them in multiple locations. As soon as one piece of hardware dies, roll out the latest VM backup onto any new piece of PC hardware you like, and you're away. No installs, no activations, nothing - just copy the VM over and press play.
I do it all the time. Have to have multiple versions of each to support all customers.
So one machine has FTView 8.0 and WW 10.1
Another has FTView 8.2 and WW 11.1
Yet another has FTView 6.1 and WW 9.5
I would like to use the Wonderware Historian ActiveX Client in View SE. I am having issues getting it to work properly. Has anyone done this...
1,757
My system consists of Opto22 controller with Wonderware HMI. These are communicating via OPC (suitelink). ControlLogix with FTView ME. I would...
2,014
...although I don't see how. We had some programmers using FTView to update some panelview screens. Turns out, they had problems with their...
4,807
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
159
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
106
