Cannot communicate to 1756-L61S
mustbemad10
Nov 2011
UK
42
I am trying to communicate the my L61S CPU, but Linx will not see it using a Serial or Ethernet connection (via my other module).
The OK indicator is on, but its Solid red. It doesn't flash or anything on startup, just stays a solid red.
I was wondering whether the firmware on the CPU may have been corrupted, so wanted to load the firmware onto a Flash Card, and load the firmware from the Flash Card when the CPU boots.
How can I do this?
I had an email reply from Rockwell saying this could be done, but the link to the page where it says how to do it is locked as I don't have a contract with them! So im hoping someone on here can shine some light on this for me.
BTW, I don't have the 1756-LSP module installed in the rack, is this necessary for the CPU to work? I don't want to use the safety features yet, I want it to function like an L61 at the moment then add the safety bits later.
Thanks.
That's most likely is your problem, it's definately a problem. Without the Safety Partner, the GuardLogix controller throws a non-recoverable major fault. I've verified on a GuardLogix system that you can't communicate with controller when this happens.
You can't use a GuardLogix processor without it's partner.
Ok, I thought that might have been the case, but I just wanted someone to confirm that for me!
Thanks for that "Timbert"
I have a 1756 L62 ControlLogix5562 controller I cannot connect to via ethernet. Get RSLinx cannot communicate message. Verision 19. It has a...
1,673
Greetings everyone, We currently are using Somachine 4.3 with an M241 processor and a HMIG5U2 w/ HMIDT732. This is my first time using this HMI...
3,451
Welcome all! //tldr on post end At first I would like to introduce myself, my name is Paul and I really like this site, but just recently I was...
2,646
Hi all.. I have Honeywell HC900 at my factoy. Recently I try to download some function blocks that I made before to it. But when I try to...
3,917
I had to reinstall Works 5k (7.2) on this system (windows XP) Ever since I have been unable to work on my project. The only functions I can use...
2,671
