Cannot edit online with RXlogix5.
Rookies007
Jul 2018
California
Silly questions.. Why can't I make edits online sometimes on some files and others I can make edits. I'm my going online with the wrong files, ects, ects.
and sometimes when I go online, it's not showing the descriptions and symbols associated that instruction/conditions. Pretty new to this and any advise will be greatly appreciated.
THANKS IN ADVANCE...
ROOKIES
Hi, Rookies welcome to the forum. Remember that rs5 stores all the descriptors in the PC, I worked with PLC5 and rs5 for quite a few years. If someone makes a change and you don't get the latest and greatest, you will not have any "annotation" as we called it. Can be pretty bad on a complex program. I've never had any problem doing rung edits while online. Hope this helped.
You cannot do an online edit if the processor switch is in the RUN position(as opposed to the REM or PRG positions)
There can be other reasons it won't let you, but that's the most common I've seen.
Edit: If you put the key into PRG you will stop the execution of the logic. Don't do this unless you mean to :)
We cannot do online edit in our PLC 5/80 CPU. It seems like it is "read only". I need an expert advice regarding this matter. Can anyone share...
2,510
This heavily loaded SLC kicked me offline during an online edit and now refuses to cancel or accept the pending edits. This is not the first time...
17
18,554
Hello friends, Two days ago something strange happened that I cannot edit data blocks ie change the contents of data blocks. They turned to gray...
7,775
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
134
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
176
