cannot set max address!!!!!!!!!!!!!
cdnrookie
Apr 2013
Canada
112
Hey All,
Im new to this (hence the name) can someone direct me in the right direction?
I am using a slc500 (fixed 20 I/o) with pic 1747 converter
I can see the plc, but it wont download, I get an error something along the lines of "cannot set max station address"
I have read all the other posts reguarding this, but to be honest im a little stumped.
I tried opening up the unit and finding the capacitor that others have said to drain (but my unit has 5 on it, so I dont know which one)
Any thoughts? Even our PLC instructor couldnt get it going (challenge accepted anyone?..........)
I have attached a few pics to show you what im dealing with
Thanks in advance
OK, so "cannot set max address is cleared (thanks!)
But now its faults everytime I try to go into run mode
I can download, but that's it?............
Sounds like the PLC program is now missing. Create a new project For the particular SLC500 model with 20 I/O that has no additional programming rungs. Download that to the PLC. See if it will go into "Run" without faulting.
Hi everybody, I have this variable (Activate1) that should be set when I activate a button from the hmi, but instead is only set as long as the...
1,238
I have a fair amount of Logix and Studio experience, but this is my first project with Studio v33 and a 5069 CPU and -IY4 card. The processor is...
1,151
Hi folks, so... firstly I have setup a hydraulic pressure test system. The system is used to pump up a volume to a set pressure - i.e. if we need...
3,297
I have a graphic that has 2 buttons for Automatic and Manual, each with pushbutton animations associated with them to toggle a bit in the PLC, one...
2,525
Hello all, I'm hoping this will be something simple, but i've been fighting it for the past 2 hours. I have an L16ER-BB1B processor that I am...
3,286
