Can't browse DeviceNet through 1769-SDN
Ok, at least we're getting somewhere now.
Is the 1769-SDN on this suspect CompactBus at firmware revision 2.2? If so, then I might have to mention that anomaly I was thinking of earlier in the thread...
Regards,
George
That's the point. Is version 2.2. the problem is that the process can't stop, so I can´t upgrade the firmware for now. When the process guys give me some trime, I will update.
Thanks again
Thanks for the info on the 2.X and 4.4 1769-SDN firmware!! I was having an issue where I couldn't get RSLinx to see my 1769-SDN when I browsed into my CompactBus. It'd only show the PLC there. I had 2 identical L37ERMs w/32.011 FW and identical SDNs w/4.4 FW. I could see the SDN through one of my PLCs, but not the other. So I was able to rule out all EDS issues. I swapped the 2 1769-SDNs between the 2 PLCs and the issue would follow the PLC. I noticed in the program I had downloaded to the PLC that my SDN had been added as version 2.02. I removed the SDN from the program and added it back as version 4.04, downloaded the changes, and then I could see the SDN finally! Hopefully this'll help someone else as well.
Is there a way to display or browse only OTL bits inside an entire project? I am developing an HMI and would like to monitor all these OTL bits...
1,175
Does the last octet mean anything? Technically the network's address is 0, but why does it give you the option in the first place?
1,584
I am trying to view some function block diagram logic, but FBD language support is not installed for my machine and I do not believe it was...
1,157
Hello, I'm configuring win-911 alarming with Ifix 5.8. during configuration it shows error WIN-911 is unable to browse for iFIX Blocks in...
1,513
Hi. I have problem with Step7 v5.5 sp4. When I try to open a project and select button BROWSE... to find project on hard drive step is hanging...
2,262
