Can't connect MP377
bakalaio
Jul 2016
US
Hello,
I have a problem with the SIMATIC MP 377, when i try to boot i get this message
Code:
- Enabling update mode...
- Loading image from flash...
- No image found...
- Waiting for imageupdate...
i can't do nothing after that message.
I search in this forum and the Siemens support forum, and i now need to reset the panel with ProSave Software.
But i can't connect the panel with my actual configuration
There my actual configuration for connection
SIMATIC MP 377 <----- RJ45 CrossOver -----> WINDOWS PC
I don't know if i'm doing this right, but i can't find the IP to connect the panel.
There some way to find the IP using only the Ethernet between PC and Panel?
You need to perform a factory reset from Prosave, which can be done via the MAC address of the MP377.
When i set the ProSave to MP377, he ask for the IP for connection
and on the last tab, i need a file with extension img
some idea where i can get this file?
The "img" file should be on the installation CD/DVD.
But.. it also installs on your hard drive when you install the software, unfortunately I don't remember the folder as I do not have a PC with the software with me.
i can use the "Backup" from another MP377?
I get this when i backup from another MP377
can i use the .img?
when i try to select this img file on ProSave, the ProSave crash.
Jjv7K2i1CqAAAAAASUVORK5CYII=
hi you need image files.chek the mp377 folder in win cc flexible from your pc drive
best regards
I have a MP377 connected by ethernet to the PN-port of a CPU 319. For my connection in WinCC Flex I can select the cpu in the project, in that way...
1,589
321
106
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
123
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
356
