Can't edit safety routines
alive15
Oct 2015
Montgomery, AL
727
Hello, I'm trying to edit some safety routines on a plc program, but everything is greyed out. Am I missing something on the software side? See photos of controller info and revision details.
controller settings.PNG safety settings greyed out.PNG studio 5000 revisions.PNG
You don't have the GuardLogix license, according to your properties image. Under Features, it should say GuardLogix
before you edit anything, you need to find out if there is a safety signature associated with the safety routines. if there is, then when you edit the routine, you break the safety signature and there is a lot of paperwork required to get the safety signature reinstalled / generated. I don't know your situation, but thought i would mention it.
james
james
"Hey boss, this is above my pay grade. I'm not trained nor certified to make safety-related changes."
Don't accept liability you are not prepared for.
RVaughan,
you are correct, if the oem or plant controls engineer made the safety routines and you edit them, that person assumes the liability. that is what i was faced with several months ago. i got with the plant controls engineer and soon learned the procedure for safety changes. they said i would assume all machine liability. i told them i wasn't going to make the changes, just notifying him what was wanted to be changed. He studied the change and quickly said no.
you are also correct, WAY above my pay grade.
james
I am creating a program for an L45S in RSLogix5000 and have several safety routines. I shut the program down Friday for the weekend, and when I...
6,971
I can't edit a safety task offline. Under controller properties, on the safety tab, it says safety application unlocked. However, I still cannot...
1,694
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
183
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
286
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
197
