Cant get tags to populate in HMI
MattMatt9
Jun 2020
Canada
119
Here is what I have done: We have a VersaView on the line and from what I know you cant do transfer utility for IPCs. So I got the MER file directly from it and converted to an MED file. I opened up the file and went to "FactoryTalk Linx" -> "Communications Setup". There is already a device shortcut. When I go to "Design (Local)" I added my PLC under "EtherNet, AB_ETH-1" clicked on the CPU, clicked on the device shortcut and hit apply. I then went to tag folder and hit "refresh all folders". It didnt work.
I have seen people do the "Copy from Design to Runtime" option but that doesnt seem to make sense in my scenario because the runtime is already working I just want the tags on the local side to be populated. So why would I copy from design to runtime. If anything I would want "Copy from runtime to design" but isnt that what the applying part is that I talked about above?
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
719
Good morning, we have a lot of coolant mist around our machines and sometimes the fans on the drives inside our electrical cabinets will suck the...
1,310
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,390
Hey guys, Frustrating issue here. I have one particular PC with Proficy 8 installed that no matter what I try, I cannot get the variable...
1,441
Hello Everyone i got a problem with Endress Hauser FlowMeter Promag W400, in his specification says it support Ethernet/IP protocol...
1,792
