Can't open .GML file
marconico
May 2018
South America
I have GML Commander 4.03 and I can't open the .GML file attached:
View attachment Msp6294a.zip
When I try to open it, Windows gives me this error:
The file is the program from a 1394 Digital AC Multi-Axis Motion Control System.
I need to open the file and edit the program in order to modify some of the process control behavior of a machine.
Thanks in advance.
I tried opening the .GML file on a true XP machine with GML Commander 4.0 and received an "Unexpected File Format" error. If this program is on a 1394 vintage controller, you may need to use GML version 3.8 or earlier. We used to keep a Windows 95 computer for that version, having difficulty getting it to run under XP.
So I would guess that either the file is .GML file is corrupt, or you will need and older version of GML programming software.
What OS? If newer than XP, you may want to try Compatibility Mode set to Windows XP SP2.
I have Windows 7 SP1.
Tried Compatability Mode set to Windows XP SP2 and got the same Windows error.
In Event Viewer it shows an Error level event with the following description:
Faulting application name: Gml.exe, version: 4.0.0.0, time stamp: 0x3821e951
Faulting module name: Gml.exe, version: 4.0.0.0, time stamp: 0x3821e951
Exception code: 0xc0000005
Fault offset: 0x000d37a8
Faulting process id: 0x1848
Faulting application start time: 0x01d3e95fbd05a8d2
Faulting application path: C:\Program Files (x86)\Rockwell Automation\GML Commander\4.03\Gml.exe
Faulting module path: C:\Program Files (x86)\Rockwell Automation\GML Commander\4.03\Gml.exe
Report Id: e8642608-5553-11e8-9b6d-606c6633884d
Also an Information level event with the following description:
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: Gml.exe
P2: 4.0.0.0
P3: 3821e951
P4: Gml.exe
P5: 4.0.0.0
P6: 3821e951
P7: c0000005
P8: 000d37a8
P9:
P10:
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_Gml.exe_ba3c606b9cd9fa2f75cd9023dcffe4f757f46a6_39deebc4
Analysis symbol:
Rechecking for solution: 0
I've also tried with all the other options of compatibility besides Windows XP SP2 (from Windows 95 to Windows 7) and got the same Windows error as before.
I got the script of the .GML program, though, so if anyone could translate it that would be very helpful:
View attachment script.zip
Thanks in advance.
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
95
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
81
150
hello I have 7cp476 cpu why can led always open and No connection
146
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
179
