can't remove types from project library
dahnuguy
Mar 2007
SC
720
tia v 15.1 1500 plc
wincc pro v15.1
Added UDTs to PLC, then dragged them over to the project library "types" to be referenced in the HMI.
Since 2 people are working on the same project, one on HMI and one on PLC, we have newer udts in the PLC edit than in the HMI edit.
The HMI programmer added udt_1 in several cases to make whatever he needed work.
Then PLC programmer updated udts in PLC.
After a couple months, there are old udts that are not used anywhere.
But they can not be deleted.
"can not be deleted because other types depend on this version...etc"
I don't care if it breaks a nested udt, I just want to delete them and everything that depends on them.
Even the top level udt will not allow delete for the same reason.
(top level has other udts nested inside)
I deleted the hmi from the project and also terminated the connection to type in the PLC.
There is absolutely nothing in the project that refers to these types except the other types.
And still can't delete them.
What is the work around? Can we edit the project file directly?
hi i ran into similar thing, i had to cross reference the udt i wanted to blow away and delete it from every other udt where it was referenced , every hmi faceplate etc
I deleted the whole HMI, same error.
Really anouying.
I would rather portal let me break a connection than just say no.
Thanks for the reskponse.
Hi, When the HMI (KTP1200 basic) powers up, the user has to enter their credentials to log in. In the screenshot, ADMIN has already logged in...
1,009
Hi I have removed at IO card from a 1734-AENTR Point IO, from a slot in the middle, and moved the remaining cards together. Now the Point IO...
680
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
2,006
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,969
Hello all, I have a project that I need to remove so I can restore a newer version on to the machine (win7). When I use the application manager...
1,167
