Siemens S7/TIA v18: How to remove "Login to Continue" button...
Mas01
Oct 2020
Leicester, England
1,109
When the HMI (KTP1200 basic) powers up, the user has to enter their credentials to log in.
In the screenshot, ADMIN has already logged in (see top-left corner).
However, the "Login to Continue" button is still displayed in the middle of the screen.
If the user clicks on it, the HMI just beeps and does nothing - which is fine, but I would prefer the button to not be there at all, once logged in.
Can anyone offer suggestions on how to do this?
Do I need to update the Visibility/Animation settings? (see 2nd picture)
Does anyone know an easy way of displaying a message box (e.g. "Login successful") when the operator has logged in?
At the moment, the "Login to Continue" button stays on the screen, even after a successful login.
In the scheduler, add a scheduled task with the trigger 'user change'
On the event 'update' add the system function 'GetGroupNumber' and specify an output tag.
Use that tag to animate the button. For example make the button visible when the groupnumber is 0.
Brilliant - that worked a treat.
Cheers.
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
669
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi, The operator has reported that, from time-to-time, when he presses the "Generate Report" button...
466
General Question: The PLC and HMI that I've been working on (a laser measurement system) is soon to be transported to the site where it will be...
701
Hi, I'm not sure how to do this... Basically, I want to restrict the user input values for this tag to be in the range 20.001 to 25.0. I...
17
1,636
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,109
