can't store to AB compact flash
sdfautomation
Jun 2012
Albuquerque, NM
I am trying to store the program in a CompactLogix 1768-L43, version 17.2 firmare, new 1784-CF64. The project does not store to the card but is lost from the memory of the CPU. A major error code 61 and minor error code 15 result from the store attempt. I tried another brand 128MB card and had the same results. I have used compact flash cards on other jobs and never had a problem. Any idea what's going on?
Major Error code 61 states that a non-recoverable error occurred, diagnostic information is written to the card, and the project does get cleared from the controller memory.
My best guess is that the CF64 card does nor have enough free space for the project, or is FUBAR, and the other card you tried may not be industrial grade (single-layer), so the controller rejected it.
Have you contacted RA Support on this issue ?
Thanks for your Response,
We purchased the card from AB tried it with same results.
Tech support wanted us to Upgrade Firmware havent done so Yet.
Also after this occurs we clear the Fault the PLC has no program we download a backup and everything is good.
Hello, For my general information and knowledge, how is querying and storing data from a AB PLC (Compact or Control Logix) typically...
7,430
while i am trying to change ip address online , plc has gone to conflict mode. Now i want to restore the factory settings for allen bradley...
17,952
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
618
Hi y'all I have a KTP400 connected to a s7-1200. Now i have on my screen the encoder value which comes from my SEW movitrac. under there I have...
401
This was asked in another forum and taken down due to being a 'backdoor', but this has useful info that might be useful to someone in a pinch. I'm...
621
