Cascade PID Loop controller
Aut0m8n
Oct 2015
NC
Hello!!
I'm working on a project that requires a Cascaded PID Loop to control solution temperature in a tank with a water jacket. The tank has two thermocouples (1) for the solution temperature and (2) for the water temperature in the jacket. The output is to heaters that control water temperature in the jacket.
The customer wants all this on a touchscreen and no small controllers on the panel.
Does anyone know of a small faceless controller that will do cascade control and communicate with a touchscreen? A small PLC would be fine if it has autotuning.
I'm directed to use an ABB AC500 processor that uses Codesys. I've downloaded the oscat library but can't find anything that has Auto tuning. Does anyone know of a Codesys library that has a auto tuning block?
Thank you!
Dear all I would like to ask you for help in solving one algorithm, because I never worked with cascade PID. I have to realize heating valve...
8,340
Hi guys, I have some questions regarding the cascaded PID loops. I am working with RSLogix 5000, and I not using the built-in master/slave...
3,903
I am currently working on a glass feeder channel firing control system. The goal is to maintain a set temp for each of 6 zones. Each zone's...
5,606
Hello All, Pls refer the Figure I am new modicon quantum also Concept v2.5 the client requirment is using a cascade loop The requirment...
6,425
Hi Folks I am beginner at plc programming and I have got some questions about PID cascade. I look for some programs( I work on Step 7, Tia...
1,347
