Cascade PID Loop questions
plc.ucd
Mar 2012
Santa Rosa
Hi guys,
I have some questions regarding the cascaded PID loops. I am working with RSLogix 5000, and I not using the built-in master/slave functionality.
This is a pre-heater application. I would like to use the outer loop to control the product temperature, and send its output to the slave setpoint. The slave loop controls the media temperature, in this case - hot water.
My questions are as follows:
The Output of the master loop is in percent. Is this the output that I send to the slave setpoint? Basically, a move instruction with Master.OUT -> Slave.SP.
The scaling on the slave loop matches scaling of the master loop. Is this correct?
Thanks so much.
Thanks for the reply, and I read through the document, but it is referencing the PIDE instruction. Our software is not licensed to have FBD functionality. I am stuck using PID loops and Ladder Logic.
Hello!! I'm working on a project that requires a Cascaded PID Loop to control solution temperature in a tank with a water jacket. The tank has...
2,399
Dear all I would like to ask you for help in solving one algorithm, because I never worked with cascade PID. I have to realize heating valve...
8,340
I am currently working on a glass feeder channel firing control system. The goal is to maintain a set temp for each of 6 zones. Each zone's...
5,603
Hello All, Pls refer the Figure I am new modicon quantum also Concept v2.5 the client requirment is using a cascade loop The requirment...
6,424
Hi Folks I am beginner at plc programming and I have got some questions about PID cascade. I look for some programs( I work on Step 7, Tia...
1,345
