Cascade PID Loop
jp1474
Aug 2006
MI
I am currently working on a glass feeder channel firing control system. The goal is to maintain a set temp for each of 6 zones. Each zone's glass temp is affected by the manifold temp of the previous zone the most. The manifold temp is affected by the flow of mixed gas measured with delta pressure across an orifice plate. The gas flow is controlled by an actuator that opens and closes via discrete outputs and gives position feedback. I have a 1769-L35E processor already in place doing some monitoring functions that is only using about 5% of the memory and plan to add this to that. My first thought is to use a cascaded pid loop for the control. I have tuned PID loops in the past, however have no experience with a cascaded loop. The idea would be to have the first pid set a target manifold temp for zone #2 based on the glass temp of zone #3. The second pid would set the target gas flow based on the target manifold temp. The third pid would set the target valve position based on target gas flow. The final pid is a position proportional that will set the discrete outputs to open or close the valve to maintain the target gas flow.
Am I overcomplicating this? The goal is to maintain the temp as tight as possible. Would it be worth it to try this with out the second and third pid's or will I get tighter control with the current setup?
Hello!! I'm working on a project that requires a Cascaded PID Loop to control solution temperature in a tank with a water jacket. The tank has...
2,398
Dear all I would like to ask you for help in solving one algorithm, because I never worked with cascade PID. I have to realize heating valve...
8,340
Hi guys, I have some questions regarding the cascaded PID loops. I am working with RSLogix 5000, and I not using the built-in master/slave...
3,900
Hello All, Pls refer the Figure I am new modicon quantum also Concept v2.5 the client requirment is using a cascade loop The requirment...
6,423
Hi Folks I am beginner at plc programming and I have got some questions about PID cascade. I look for some programs( I work on Step 7, Tia...
1,345
