Cascading PID Loops Siemens TIA V12
dabanani
Feb 2009
Mo
85
I am wondering if its a good idea to cascade pid loops. For example If I want to control two variables Current and Voltage. If i can feed output of the Voltage PId in to the Current Pid to create a cascaded control loop.
Thanks any help will be highly appreciated.
It depends on the application.
You can't control two variables at the same time. You can control one and limit the other. You can work out a cost function and minimize that.
You need to state EXACTLY what you are trying to do.
I am trying to control output of a rectifier either by current or voltage. And i want to be able to switch this control at any time. So i can start my process by controlling the voltage and at any time i can switch to control by current.
I have both current and voltage feedback, and controlled variable = rectifier firing angle.
Its going to be for heating for a school project. And all i am required to do is provide either constant current or voltage at any given time. So i am thinking of feeding output of the voltage pid into current pid so that i can control the output either by changing set point on current or voltage.
Please let me know if this is possible or if its a good idea. Or what is the best way to go about this
Can someone help me understand cascading PID loops? We are controling a steam valve through a heat exchanger this way, and I am having trouble...
2,999
I need a little help tuning this system. I am using a SLC 5/05 processor. What I have is a paint booth that requires me to be able to control the...
4,616
Just curious to see what are some of the more favorable methods? I have never used one before and will be commissioning one in the near future...
3,069
Ok! I could really use some help getting off the ground with this one. I have in the past programmed cascading PID's but for some reason I...
4,334
Good Evening , I have a Conveyor system that requires Speed Cascading from one conveyor to another. Meaning that if one conveyor speed is...
2,603
