CCW 850 A-B problem
cdean
Apr 2016
il
I have a program that I'm working on in CCW that has 4 ladder subs in it, for some reason... when I set a coil and make it a global variable, when the line = true it will not pick up the coil
has this happened to any one ???
as far as I know if the ladder line is true all the way to the global variable "Coil" and it is set as an bool It should go true.
p.s. I change it to a local variable (for testing) and it works fine in the one ladder sub that its in but I can not use it anywhere els in my program.
Fixed it
Just an update if this happens to you:
1) I removed the global variable from the variable table then saved
2) remade the global variable from scratch and it worked
I don't know why this happened but saving it without it, then remaking it fixed it hope it helps.
UGGH!! And I am just delving into this ghastly software for a new customer's project. Really disappointed in this product, banging my head at even the simplest stuff.
FREE software! YES! TIME is MONEY! Time wasted with the type of bug you describe is inexcusable.
CCW = [Complete C**p Work] :mad:o_O
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I donā€™t have a file on my...
351
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
332
I'm controlling an Applied Motion HW23-601D using a Leadshine EM542S connected to a 2080-LC50-48QBB, using CCW, and experiencing some weird...
626
Hi All, Hoping the community here can help as I'm new to PLC programming. The project I'm working on is using a Micro850 2080-LC50-24QBB and...
1,726
Hi, I can't connect to a Rockwell Micro850 using Connected Components Workbench (CCW) 12.00. - I can ping the PLC - I can flash the PLC (from 10...
1,535
