Micro 850, CCW 12, can "see" it, can't Connect
Saulo35
Jan 2012
Port Coquitlam, BC
112
I can't connect to a Rockwell Micro850 using Connected Components Workbench (CCW) 12.00.
- I can ping the PLC
- I can flash the PLC (from 10 to 12)
- I can "see" it in CCW's Connection Browser, both via USB and via Ethernet (that's how I found the IP address, 168.254.228.4)
However, when I click on "Connect", nothing happens.
PLC Hardware:
- 2080-LC50-24QBB
- Slot 0 empty
- 2080-TC2
- 2080-TC2
- OW16 Expansion I/O
The PLC, the laptop and a Micro HMI are connected to a simple unmanaged Ethernet switch.
We tried a different laptop that had CCW 10 in it (we flashed the PLC back to 10), with the same result.
Any suggestions?
Thank you
I had the same problem. Call support on Monday. There is a .dll file in the wrong place.
For two weeks those guys told me it was my fault.
Hi everyone, I would like to use Micro 850 to control DF FC 102. I adready connect Danfoss fc 102 VFD ( it can run the motor) to Micro 850 by...
1,932
I am trying to read and write data from Control Logix L23E and a Micro 850. My path in the message is 2, 192.168.2.183 192.168.2.183 is the ip...
714
Hello. I have an issue with a Micro 850 PLC. Issue is when it is in RUN mode, and an output is energized, the whole PLC just turns off, then turns...
841
555
I am using a Micro 850E PLC (the new one with implicit messaging capability) to drive a Kinetix 5100 servo drive. The error code number on the...
1,717
