Micro 850 Issue
eddicuss
Oct 2021
California
Hello. I have an issue with a Micro 850 PLC. Issue is when it is in RUN mode, and an output is energized, the whole PLC just turns off, then turns back on and reboots. As soon as it transitions to RUN when rebooting, it turns off again and just does this never ending cycle.
The only way to recover is setting the switch to PROG on the PLC then redownloading the firmware. When setting back to REM or RUN, it's fine, but then when one of the rungs are true to energize an output, that issue mentioned earlier happens.
Hello. I have an issue with a Micro 850 PLC. Issue is when it is in RUN mode, and an output is energized, the whole PLC just turns off, then turns...
839
I am trying to read and write data from Control Logix L23E and a Micro 850. My path in the message is 2, 192.168.2.183 192.168.2.183 is the ip...
713
I am using a Micro 850E PLC (the new one with implicit messaging capability) to drive a Kinetix 5100 servo drive. The error code number on the...
1,714
Hello, and thanks in advance I am working on a project with two micro 850 controllers and want to send bool bit from one to the other. I am in...
1,139
Hello Everyone, I am trying to connect a A&D EK-6100i Weigher to my Micro 800 PLC and read the current weight. For now I have managed to connect...
4,190
