CCW and Windows 10
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello, Has anyone been able to use the latest version of CCW on Windows 10? I read a tech note in KB acknowledging there is a problem, I just wondered if anyone has found a work-around? Thanks.
I have used CCW standard v11.00 on Windows 10, it works for me basically correctly.
The only problem I found is that I have never seen before a PLC programming tool as slow as this one.
Before installing v11.00 you have to uninstall any previous beta versions which you might not realize you installed (it might have been beta without you knowing it was beta). Best bet with v11.00 is to uninstall any previous versions you had before installing it.
Did this several times. Wiped any trace of CCW. I went to AB Tech Support and they told me this is a known issue. They gave me a tech note to follow but that didn't help either.
I have 10.1 installed on a W10 machine and runs fine
Hmmmm. No matter what I try I cannot get mine to go online with PF525 control module. It shows that it is online but will not transfer anything to it. I use it on Windows7 and it works fine. Like I mentioned above, I contact AB tech support and they told me it is a known issue. I tried what he told me too and he ended up telling me to just use Windows7. Lol
This is probably verging on derailing the topic, but are any of you using the Developer edition for version 11?
I'm still running Standard edition v10 but need to upgrade soon.
The Rockwell website claims the Developer edition has the ability to copy ladder logic from RSLogix 500. Any reviews on how well that actually works?
Also I still find CCW a painful software, but my biggest grievance is not being able to do online edits. How do the rest of you deal with that?
Version 11.1 is suppose to be coming out soon and will have the ability to emulate RSLogix500 and 5000/Studio (so I'm told). If you install developer (I believe) you will run into the same issue of having to completely uninstall it before installing 11.1 but I don't know that for sure.
Hi guys, pretty new here so bare with me. I'm currently trying to install Connected Components Workbench V13 (I've tried V12 aswell) but I keep...
1,327
Hello everyone, hope all is well. I have found the time to start back messing around with my little micro 830 PLC.I remembered how CCW standard...
998
Is anyone using CCW and Windows 8.1? Any input would be appreciated and where do I get the latest CCW? I think they only have it as a download...
2,107
Anyone using windows 8.1 with AB CCW and other PLC software packages? Need some oppinions. What version are you using?
3,261
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
104
