CCW Document Generator does not print tag names
drbitboy
Dec 2019
Rochester, NY
8,097
Has anyone seen this? Am I missing something?
See the images below: the image on the left is from CCW; the image on the right is from a PDF generated by CCW's Document generator (the MSWord .docx has the same issue).
Is there some configuration setting where I changed my printed font color to the same as the background?
Here is the version info from the [About] dialog:
Connected Components Workbench
Version 13.00.00 - Standard Edition
http://ab.rockwellautomation.com/programmable-controllers/connected-components-workbench-software
Copyright © 2021 Rockwell Automation Technologies, Inc.
All Rights Reserved.
Installed Components:
Micro800 Controller
13.0.0.201
Copyright © 2021 Rockwell Automation Technologies, Inc. All Rights Reserved.
Unified Device Configuration for CCW
12.8.0.0
4.8.0.0
Wizards
4.8.0.0
DeviceLogix Configuration Tool
8.1.0.3
Copyright (c) 2020 Rockwell Automation, Inc. All Rights Reserved.
PanelView Component DesignStation
12.1.0
Copyright © 2019 Rockwell Automation Technologies, Inc. All Rights Reserved.
Guardmaster 440C safety relay
7.2.1.9
Copyright © 2020 Rockwell Automation Technologies, Inc. All Rights Reserved.
450L Safety Light Curtain
5.0.1.10
Trending
3.0.0.0
Another data point
@OldChemEng ran Document Generator on V12 and the tag names show up in PDF and MSWord for him.
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
66
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
245
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
172
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
110
