CCW - problem with build
rQx
Oct 2010
Trelleborg
1,051
Ok, so I'm pretty new to the software CCW and I can't find where the error is when I build my program. I get two errors
BACKWASHCLEANING(194,0): Error 0013-0000: =:must precede a BOOL expression
BACKWASHCLEANING(194,0): Error 0059-0000: AND:unexpected statement
It doesn't link me to the problem when I click on it.
I've tried to remove all the rungs to see if that was the problem but same problem. I know if I delete some of my rungs the problem dissappear but I don't know what the problem is.
Anyone has an input. Am I missing something in this new software?
btw, I hate the software, so complicated to work with so I'm not suprised if I made a rookie misstake.
http://speedy.sh/x89x8/800-filterautomatik.zip
the FB block is not accepting rungs 22,18 and 14
for a test I deleted in that order Highest to lowest and it will then build OK
Did the error code lead you to that ?? rung 194 didn't make a lot of sense to me... Doesn't seem to like the aliased timer bits...
the actual rung number is not displayed
at the first fault was 194
I added a contact in one rune - 194 went to 195 AHAH
so picked the last rung and deleted it - no fix
of course once you build it you need to replace the prg again so unzip it again
I tried a middle rung 194 still came up
when i tried 14 194 went to 237 = more than one fault
found that the timer contacts were used in three rungs
that fixed it.
I did not worry about going any further
I am sure the OP can do that
Thanks alot for this help! It worked great!
Is it just me or is this CCW the worst program ever? New question came up, how do I debug a User defined block? I run the debug but it wont show me anything, only the Main program is available to be debugged :/ I ask here and maybe I'll start a thread if answer is not aquired.
The program is a pain. But no real difference to other AB. Stuff
I don't remember the debug function in an FB. The reason is the last version I used was V4
However I would have had the DRUM function in its own POU instead of an FB
The reason is that the FB is normally used for multiple instances. A Drum sequence is normally used once.
I noted in the V1 that the analogue Scale FB can not work inside a user designed FB
This might still happen
It is a pain alright! I'm fairly new to AB stuff aswell so it doesn't make it any easier.
You meen the backwash sequence?
I used the FB because I will use this FB in other programs aswell , thought it might be easier to integrate it into my project if it is in a FB.
I think I also have found out that you cant use "timer.IN" function. I used this to trigger a SR but it didn't work.
You can copy and paste POU's also. Remember the global labels all will be ok.
Hello everyone, I'm having issues with connected components. I got a new laptop and I installed all the RA programs I need without problem. I was...
354
Hi, I am having a problem with the CCW v20.1 from Rockwell. It is the first time I am using it, as I used to work with Siemens or RsLogix, but...
2,106
Hi All Could anyone advise me on how to protect the push button on the screen from occasional touch? I've faced up the problem that I can't...
22
6,586
I have a Connected Components Workbench Panelview 800 application I've been working on, along with a Micro 850. It has been going reasonably well...
7,775
I have a program that I'm working on in CCW that has 4 ladder subs in it, for some reason... when I set a coil and make it a global variable, when...
2,079
