CCW-Rslinx problem
Jansan
Dec 2022
Spain
Hi, I am having a problem with the CCW v20.1 from Rockwell. It is the first time I am using it, as I used to work with Siemens or RsLogix, but when I try to configure a driver, search for a device, download, etc RsLinx browser is not popping up and I get the message "Unable to find RSLinx Browser.".
I also checked with v21 and v13 but they were also not working.
I have also tried with the RsLinx window opened but same message is shown.
Do you know what could it be?
Thanks!
Try changing your CCW communications software from RSLinx Classic to FactoryTalk Linx.
In CCW select Communications --> Select Communication Software --> FactoryTalk Linx and press OK
That option is not active in my case. Maybe because when I press the "configure drivers" button nothing occurs?
FactoryTalk Linx is a completely different program. You can choose from LogixStudio 5000 the communication program (RSLinx Classic or FactoryTalk Linx) but you need to close the project.
Hi Alfredo, in this case I do not have FactoryTalk Linx. I only have the free software as I am not a regular PLC programmer for Rockwell. In this case I only have CCW and RSLinx.
I cannot understand why in my computer it doesn´t work and in my colleagues laptop it is working properly.
I have installed the FactoryTalk Linx and now I have both communications softwares in CCW. I tried with both and still the same problem.
RsLinx and FactoryTalk Linx alone work properly. The problem is when I try to do something about communications from CCW. Even pressing just the "Discover" button, nothing happens...
Try to reset CCW software settings.
Tools-->Import and Export Settings...-->Reset all settings
I tried the "Reset all settings" and nothing... It should be a compatibility problem with other software or something like that...
Do not worry guys, I will work with my colleague´s laptop. Thanks for your repplies!
Well, if you ever figure out what is causing the issue and/or fix please report back, so the pull your hair out moment can assist others...
Did you try starting CCW in elevated mode, that is launching it as administrator ?
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
64
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
241
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
171
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
109
