CCW V11 Print icon removed?!?
JZerb
Oct 2016
Here
423
So when i would program a drive with CCW i would usually print to PDF the parameters of said drive so it can be archived. this was quite easy in versions past because there was a PRINT icon in the upper right of the screen within CCW where one would view the parameters. has that been removed? or am i just going crazy because i cannot seem to find it and Ctrl+P doesnt seem to do bubkiss for me neither. :confused:
In Windows 7 and Windows 10 there is that 'Snipping' tool . . . enables one to
select a portion of the screen then save that as a JPG. Does that help?
Also, the Ctrl+P . . I used to do that then open the Paint program and paste
what the Ctrl-P captured.
So, I assume you are speaking about 'Connected Components Workbench' for
programming VFD's? I have about ten such VFD's and the program (don't know
which version) but, so far, we have not had any problems with them. (Might be
good to learn more about this . . .)
Poet.
I can't find it either! I looked thru the toolbars menus too. I too hope I just missed it
It seems that when they did the upgrade from 10 to 11 they forgot about the print button.
But on a side note there is a update to get trending for drives in CCW, this link should take you to the download search page for the trending add on.
https://compatibility.rockwellautomation.com/pages/search.aspx?crumb=117&q=trending
Alan.
Interesting... I'm usually all over new Rockwell software updates but this one flew under the radar for me.
Thanks for the heads up!
I do the same thing - create a .pdf of all of the parameters for future reference (and has saved my butt a couple of times). I use a freeware document to .pdf converter though Primo PDF. I like it, been using it for years. Give it a try.
EDIT: Reread the post, I misunderstood the OP. No option to print at all.....my bad.
Been out of the loop for awhile but like Test below I am back. I left off with V8 something. It had that annoying collor transition for blocks...
1,408
Hey All. I had a regional Rockwell Component Specialist tell me yesterday that CCW V11 was available for download.... I can't seem to find it...
2,120
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
235
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
169
