Ccw v11??
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey All.
I had a regional Rockwell Component Specialist tell me yesterday that
CCW V11 was available for download.... I can't seem to find it, only V10.01 on the downloads site.
Has anybody found V11 yet?? I can't bug him yet, its still very early here, and even earlier where he is.
You've got to keep tabs...
Hi Folks,
CCW v11 is "hot off the press" but not left the "printers" yet. If you look here (where ye are most likely checking?)...
https://www.rockwellautomation.com/global/support/connected-components/workbench.page#tab4
...you will be viewing the "Downloads" tab on which you'll see CCW v10.01 is available as the latest version.
However, if you slide across and go to the "Overview" tab...
https://www.rockwellautomation.com/global/support/connected-components/workbench.page#tab1
...you will now be able to read information on what the Specialist was referring to. Version 11's release is imminent (some time this month). If you keep "tabs" on this webpage (pun of the day!) then I'm sure soon enough you'll see that v11 will be available in the "Downloads" tab.
Also note the mention of the "Feature Pack" release, due soon after around May 2018, and the features it will introduce.
The introduction of, and support of the new & more endowed Micro 870 controller is, I suppose, the most notable addition to this version.
Regards,
George
I've also just double-checked the Product Compatibility and Download Centre (PCDC) and v10.01 is still listed as the latest available.
G.
Been out of the loop for awhile but like Test below I am back. I left off with V8 something. It had that annoying collor transition for blocks...
1,408
So when i would program a drive with CCW i would usually print to PDF the parameters of said drive so it can be archived. this was quite easy in...
2,722
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
235
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
169
