CCW word datatype
fjviloria
Mar 2024
Miami, FL
I have an AB micro820 analog inputs takes word datatype to scale my input to 0-100% , i need to know the word datatype range does anyone knows?
thank you
Frank
put 16#FFFF as the value of tage **ffffs** and 16#0000 as the value of **zeros** as the value of two Words. Then compare **> zeros ffffs OTE abool**.
If **abool** value is 1, then the range is -32768 (16#1000) to +32767 (16#7FFF), otherwise it is 0 (16#0000) to (16#FFFF)
Hello, Does anyone know how to address a output word in CCW? I have done this with just about every other PLC made but no luck in CCW, I also...
2,599
Hey, folks, me again. I have an AB Panelview 800, using CCW standard edition V. 10.00, with RS 5000 V. 20.04 in a 1769-L18ER. On this job, there...
4,663
Anyone heard anything as far as when Connected Component Workbench 8 will be released and what will be new in it. I hope they finally have some...
1,941
I'm trying to use a 2080-MOT-HSC (high-speed counter) in a AB Micro850. I downloaded the UDFBs, and imported the function block that would suit my...
4,128
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
67
