Change 1756-CNB with 1756 CN2
AFPC
Feb 2011
Damascus
Dear all
I have an ALLEN BRADLEY PLC system with a local and a remote rack. On the local rack I have 1756-CN2 and on the remote rack I have 1756-CNB
I need to replace the controlnet bridge on the remote rack 1756-CNB my questions are:
1- Can I replace a 1756-CNB with a 1756-CN2
2- Do I have to change the configuration and reschedule (which I suppose will necessitate a shutdown of the plant ).
3- what about replacing 1756-CNB with a 1756-CNB but with a different version ( A or B)
Thank you
Good morning, I have a system on 1756 L73 that works with supervisor on EN2TR modules. Everything works correctly, except that EN2TR (1) with...
521
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
847
Good Evening , We have a number of Kinetix 6000 Servo drives ( fiber ) that fault out from time to time . I would like to change out the...
5,297
I want to change SNMP in the 1756 ENBT(AB product) from public to other word. Please help. Thank you in advance.
5,183
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
