Change Buttoncolor in WINCC
userxyz
May 2002
any
2,768
Hi, I'm a beginner in WinCC and would like to change the color of a button when a certain picture is vieuwed. I made a navigationmenu.pdl, a status.pdl and a main.pdl. In the main (startscreen) I placed Status.pdl in the top and Navigationmenu.pdl in the bottom. In the middle the pictures mon1.pdl, mon2.pdl, ... are showed when a left mouse event happens in the navigationmenu.
I made a 16 bit Unsigned Tag, every buttons sends a constant value to this tag. That's the way how I call picturenames.
What do I need to know: How can I write this in C or VBS. I am a beginner and don't know how to write this.
The color of button1 for example is coupled with the value 1 of the screens tag. when picture mon1.pdl is showed in the middle, the color of button1 must become yellow for example
Many tnx.
Hello Combo;
Here is the recommended (by Siemens) way of making a object property dynamic:
Open the properties of the button (right-click on it), select Colors; make the colour dynamic and use a Tag or a Dynamic dialog to change the property following a tag value. There is no need to do this in C-script or VBS; also remember thet every script you add will consume more processor time; this will eventually show up in the update time of your screens and becomes quickly irritating.
Hope this helps,
Daniel Chartier
hi
maybe a little question,
when I do it analog, then it's UPTO value, all the other buttons are changing to, when I choose button 8, then 8 buttons will change...
So it works not fully 100%
Bit isnt the solution I think, because I use constant values to change Picture windows...
Have u an Idea ?
Hello Combo;
If you want to do it with analog (there are other choices) you can set ranges: 2 to 2, 8 to 8... that will apply your dialog to only one value. At least that is how i remember it.
Hope this helps,
Daniel Cartier
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
177
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
188
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
75
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
172
