Change computer name of a wincc advanced v13
I will give you an example : All my experience is based on Rockwell Software if you change the name of a client pc you will no be able to log on again on the SCADA server.
WinCC Advanced does not have Client/Server functionality.
The only bad effect I can imagine that you can no longer remotely load a PC Station that is combined WinCC + Simatic Net installation.
WinCC will continue to operate independent of its own Name.
Transferring a WinCC project uses the IP Address.
But transferring a Simatic Net project uses the Device Name, so that is the scenario that could be affected.
Here is another potential (indirect) bad consequence.
If there is some network monitoring system in place, changing any device name can generate false errors.
This includes the Diagnostics of Siemens canned system functions, especially if the Topology is fully configured, i.e. all devices, cables, ports, names etc.
This also includes the Diagnostics programmed into the HMI programs on other WinCC panels or HMI stations.
Everything will continue to operate, but there might be false errors.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
177
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
188
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
75
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
172
