Change Profiles In A Lighting Controller
esp400
May 2015
Milwaukee
69
I'm trying to figure out a way to change profiles in an Advanced Illumination DCS-100E lighting controller through the PLC (an AB 1756-PA72). The controller supports SCPI commands:
From the AI manual:
The DCS100 uses an SCPI-like interface where commands are a series of readable strings with parameters separated by commas. The strings must be terminated by a semicolon (‘;’) for proper operation.
Commands can be sent in an ASCII format by specifying the IP Address and correct port number for either TCP/IP or UDP.
I'm wondering if there is a way to use the AB PLC to control what lighting profile the lighting controller runs when it is triggered. Lighting controller will be on the network switch for the machine and is addressable.
If you know a way to accomplish this, please let me know.
Thanks!
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
155
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
188
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
75
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
172
