Changing A-B IP Addresses
AS91Racer
Aug 2008
Indiana
Hi. I was recently tasked with changing the IP addresses on 3 ControlLogix, 1 SLC 5/505, and 1 HMI computer(InTouch) on a working system. Everything seemed to go reasonably well (all devices are pingable from the HMI box, the system mostly works, InTouch responds as expected, etc.). However, there are several (all) MSG blocks in the SLC that are now setting the .ERR bit after changing the IP address under the multi-hop tab.
None of the PLC's have been power-cycled, but all have been stopped/started. All devices are also pingable from a troubleshooting laptop. Monitoring the .ERR bit with Rockwell's OPC Test Client is what is what is showing me data changes. The IP addresses were changed from a private range to a public range. All devices are connected to the same (unmanaged?) 3Com switch.
Again, this system worked prior to the IP changes.
Is there any history with MSG block failures after IP changes?
Is power-cycling a no-brainer?
Any trobleshooting tips/procedures?
I'm pretty confident that I've discovered all of the MSG blocks and communication paths in the system, but next steps for troubleshooting are escaping me.
Thanks in advance.
Using studio 5000 with 1756-L71 and 1756-ENBT cards. Is it possible to change all IP Addresses that are being used for a plc, drives, enbt cards...
1,474
Hello, I recently changed the IP address of a Compactlogix L32E and an asssociated Panelview 1000. I can ping both of them so I know that the IP...
5,532
I’ve been asked to help move some PLC’s & HMI’s behind a firewall. Part of the move requires assigning new IP addresses on SLC’s, PV+’s and...
2,437
Hi, Today I was experimenting a little with TIA portal but I have a problem with changing the addresses of a DP slave. I've configured the CPU...
2,877
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
