Changing of IP address of Compact Logic L35E.
AB2005
Nov 2006
Lahore
320
Hi;
We have a problem in a PLC Compact Logic L35E which could not be rectified yet but program inside it is save. I want to download the program to another L35E which already has a program with a different IP address. I need info how to change the IP of PLC which has already assigned an IP?
Hi - if you can view the PLC from RSLinx, then simply right click on the icon, select Module Configuration. From the Pop Up select the Port Configuration Tab and enter the desired IP address.
If you want to do it offline and download then refer to attached screenshot.
Solution 1.
Remove left end cap and disconnect battery for a while (several minutes as far as I remember)
Then use BOOTP.
Solution 2.
Connect to the serial interface (RS232) with RSLinx.
Browse down to the internal ethernet port, right click and change port settings. (I cant remember what to left click on after the right click, but when you see it I think you can find your way)
Solution 3.
Feel lucky an guess. :)
I'm trying to configure the IP address of my compactlogix l16er-bb1b in Studio 5000. I need to set it to a certain address as I'm planning on...
3,308
I’m an IT “fixit” guy working at a manufacturing plant that volunteered to help out with PLC’s. I know about .001% of what there is to know so...
3,799
I'm running ME 9.8 and I can get online with my Versamax processor via ethernet just fine. But for the life of me, I can't change the IP address...
1,801
I am using a Micro820 controller setup with the Modbus RTU in slave mode. Is there a way to change the slave address from within the application?
2,461
Does anybody know how to change the IP address of the series A flex IO comm module? This is the one that doesn't have the helpful 3 digit wheel...
2,462
