Changing type of input in 1734-IB8S
cardosocea
Nov 2016
Fields of corn
2,639
Hello,
I have a running system where I'm completing an overfill protection logic and noticed that one of my feedback inputs is configured as "Not Used", and doesn't change state when I apply a signal to the input. This is to be changed to Safety, but when I am about to apply, I get a notification that I'll lose connection to the module and I'm wondering if doing this change is something that will reboot the processor or not.
Is there anyone that had the same predicament before?
I've made this same change online while commissioning in the field with no issues.
The processor does not need to be rebooted and the change "can" be made online while the program is running.
If I remember correctly, when you apply the change the IB8S card reboots, so all of the inputs on that card will go low until it comes back up. How your safety logic handles this may be different than the systems I worked on.
I wouldn't make the change while the machine was running unless you understand what effect all of the safety inputs will have as the module reboots.
I am trying to use RSLogix 5000 to load a project into a processor that is different from the one in the program. I tried to change the processor...
5,315
I received the program for a compactlogix plc in the form of a BAK file. How do I change the file extension from .BAK to .ACD so I can open it in...
2,498
Hi all, I have an existing project and I am modifying it to my project since they are similar. I noticed the controller types are different. Is...
3,780
I have a half-prewritten PLC program supplied by a manufacturer that used real hardware. I want to download to softlogix virtual chassis to...
1,973
Hi-there is an A-B binary clock download on this site that I am trying to view with my logixpro simulator cd. Is this possible to do? I have a...
2,270
