Cheaper PLC for driving five stepper motors
FiveO
Feb 2016
Est
Hi
I have 5 stepper motors with drivers(each can support pulse up to 300kHz) and I want to control them with PLC. Also need to control ramp.
Additionally I need 2 outputs and 2 inputs(2 relay output or control and 2 sensor input). Each stepper motor needs 2 outputs.
Is it possible to find something suitable below 200 euros of dollars.
English isn't my first language, so please excuse any mistakes.
yes there is look at arduino, it has far better speed and is cheap 25 $ max.
and 300 kHz is only the pulstime, the steptime is way longer.
google accelstepper or multistepper and your eyes will fall out.
a NANO for 3$ can do this trick.
You might be in a tricky spot. I know at least with Siemens PLCs, 4 motors is the point at which you need to move up from a cheaper micro PLC (S7-1200) to a more expensive "full" PLC (S7-1500).
I'm not sure where other vendors make have their cutoffs, but I know they like to try to match each other's specs, so my guess is they are similar.
You may want to utilize the data port on a PLC to drive individual controllers for the price range you are looking for. Stepper motor cards are pretty darn expensive.
Greetings,
Based on the number of steppers you are talking about, likely requiring a PWM, you may need multiple PLCs to do so.
We are a distributor for Triangle Research, whom offers the FMD series with Stepper capabilities. More information is available through the following link:
http://www.eternity-sales.com/tri-plc/fmdseries.htm
It is an industrial embedded Ethernet PLC.
If you would like to discuss your requirements further, we can do so through this tread, pm or you can email me through the link provided below.
Disclosure - ESI is an authorized TriPLC distributor
Hello all, Has anyone tried a more economical alternative to the 9300 RADES (Allen Bradley PLC modem)? Thank you!
2,765
It is very expensive from RA. Did anyone here have this software(plc-2 A.I. or 6200) and didn't use it any longer? please contact me at...
2,967
Hi Guys, Can anyone recommend a cheaper alternative SCADA package to SE? Its approx €1000 per runtime (15 screen) and I'll be buying quite a...
4,321
Is there a cheaper Ethernet to Modbus bridge than the 174CEV30010 from Schneider? These bridges are over $800.00 a piece from Schneider...
7,457
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
51
