9300 RADES PLC modem cheaper alternative.
Elcan
Apr 2008
NC
935
Hello all,
Has anyone tried a more economical alternative to the 9300 RADES (Allen Bradley PLC modem)?
Thank you!
What I found last time I dug into this was that the 3COM LanConnect and Shiva NetModem devices that had similar feature sets had been discontinued because of low demand. They were hot stuff in 2001, though.
Thank you!
I thought there were plenty of options nowadays. There are still many places in the world where an analog telephone line is the only communication available for remote plants in the middle of nowhere.
Panelview 1000 Connection Help
I have a panelview 1000 that I am trying to upload a make a small change and I am having issues connecting with panelbuilder 32.
The panelview is connected by the rs-232 port to a SLC 5/04.
I have cable # 2711-NC2 and Cable # 2711-NC13.
In the config screen on the panelview it has
Max Node 21
Node 2
Baud 19200
I don't see how you would set this up in rslinx? I have linx 2.57.
I have tried to use the RS232 DF1 driver with no sucess using autoconfig and manual and made it a different done from the panelview.
When i try to use the point to point driver in panelbuilder 32 it starts rslinx? Even though i have shut linx down and it is not running in service mode?
What can I do to get connected?
less expensive
Lately I have been using a product by *********.net with great success. No remote dialing but great with ethernet. I service GE and Rockwell all over the world from my site in the USA.
Can someone give me a quick, blow-by-blow description of what needs to be done to connect to a Compact Logix or Control Logix PLC through an Allen...
1,439
Hello All, I have a question about the setup of a 9300-RADES dialout ethernet modem for communications to SCADA system. On one end I have a...
3,203
Am I correctly assuming that there is no need to assign the 9300-RADES to a ControlLogix rack, as this device is simply a means for Ethernet...
1,839
Anyone ever encountered an A-B Ethernet modem that wouldn't answer an incoming phone call? Any suggestions?
2,931
Has anyone experiencing problems with this device? To me it looks like its a plain piece of sh*t and I'm looking for a replacement from another...
3,978
