chinese plc
john123
Sep 2010
london
18
hellow
i need help
to change a parameter on a swg wind turbine plc
got usb to 485 lead and driver
driver for plc
when i click upload it say fail to wright time out
not sure what is wrong
i need to lower parameters on plc or adjust anologue return signal from anemometer to required setting
3 wire 5v /gnd/signal.:confused: looks like a optical incoder sensor
new to this / just started/ ect
any help will be greatfull
regards
john
Johm,
Is it a Chinese-brand PLC called "SWG"?
When I click upload, it says "Failed to write, time out"
This probably means that your changes to the PLC program were not used. There can be several reasons.
The first one that pops in my head is that the PLC program could be password-protected.
The second one is that you may not have established communications with the PLC. This one is a puzzle, because I ASSUME that you downloaded the program so that you could change it. If you downloaded the program, but cannot upload it, then most likely the PLC prpgram is protected with a password or some other method that causes it to be Read-Only.
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
230
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,110
Hello; In one of our Chinese flexo machine, there is a Chinese made PLC, brand "XINJE" Model XC5-48R-E. We have its programming software but all...
2,071
Hi All got a Chinese PLC named Thinget xc-3. They have sent me a user manual....though it is in english, i cant understand a thing...
4,329
I have an old Chinese Temperature PID controller XMT 8038c2kp that am able to send and receive requests via Modbus poll test center in this format...
450
