Ciea metal detectors large metal fault issue.
Saudi jamal
Jun 2015
oman
147
Dear guys,
Today I have been installed 2 no of ciea metector model G21-200.now my problem is if I power on first metal detector & observed it is working good and if I power on for 2nd metal detector then first metal detector is not working.I mean at the same time only one metal detector is working.I am trying run both detector at same time but both are showing large metal fault.
If somebody has any idea kindly help me to solve my problem.
Kind regards.
Jamal.
Dear guys,
My metal detector problem has been solved. It was malfunctioning due to both metal detectors are near by each other. Finally I changed configuration mode transmission channel TX 2 before it was 1.now one m/c TX 1 and other m/c TX 2.
Both m/c is working fine.
Thanks all and best regards.
Jamal.
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,155
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
842
Currently my company has a MT metal detector model V4 that has been down for the better part of a month. The metal detector is giving a F06-5 IO...
3,132
Good Morning , We have a new Fortress Stealth Metal Detector. About 30' away we have a machine with motors and solenoids on it , Whenever...
2,207
Good afternoon all, hope everyone is doing well. I have a mill cutter application which mills into our iron casting part. I am using duct hose...
2,405
