cimplicity and s5 plc
alijunejo1991
Apr 2014
KARACHI
hi everyone !
how can we communicate cimplicity hmi to s5-95 cpu?
is there any user manual if not, kindly tell me how and which protocol can be use for communication ????
You will need to do your own homework on this.
Or include enough detail in your question for a good guess by someone.
You need an OPC Server. Which one depends on what version of Cimplicity you have.
For versions 6.1 and prior, go direct to KepWare.
For at least version 8.0 and higher, GE-IP licensed KepWare and sells it as the IGS Drivers package.
The actual protocol, setup and points are up to you.
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
238
Hi All, I'm using AB plc 5370(Modbus TCP slave progm type) with GE cimplicity scada V8.1. For DI,DO,AI communication is working good. But, I...
2,579
Hi, I'm encountering a fault on a remote I/O node that is communicating with a Genius Bus Controller. The site can not risk stopping the...
1,645
I have no experience of cimplicity. I have Siemens S7-400 PLC with GE Cimplicity SCADA.Unfortunately PLC not communicate with cimplicity .My...
1,136
Hi All, I have just started using GE PLC and wish to check for some information. I was able to connect to my 90 - 70 PLC with COM1. I would...
2,914
