cimplicity problem
madi.bj
Jun 2013
Tunisia
After changing a windows password of the session where we are running a cimplicity project we are no more able to write values to the PLC.
In the project we have two stations and for the two we are only reading values from PLCs even the update configuration is disabled and in the log we are getting PRT data collector is not licensed!
please advise
This could be a number of things. Lets start with the simple.
Have you looked at your Cimplicity users list in Workbench? Maybe you just need to set the password for that user in Cimplicity - depends how you have this project set up. Do all users have this problem?
please advise
Is it possible that you have an IO Server running as a service using the credentials of the username whose password you changed?
nwboson: yes all users have this problem, and the logged user is administrator and have all the rights. I remark also that I'm not even able to update the configuration of a project or add new project all the functionalities in the workbench are disabled.
Also when i start a project i'm getting the message "don't perform single coil writes" !
Bit_Bucket_07: the IO server is running since we are reading the values the only problem is writing
here is a screenshot of the status log
https://drive.google.com/file/d/0B-SQwiQTgh7nZFRqNjZmaGg3bTA/edit?usp=sharing
Hi I have problem with cimplicity 7.5 can any buddy help me regarding this. Actually I am using a cimplicity 7.5 as a SCADA and Delta PLC...
3,762
Hi All in table logging attribute tab i checked for on digital point high for virtual point. but when i change this point from 0 to 1 no data is...
2,264
Dear All, i am facing one Ethernet communication problem with versamax system and cimplicity 7.0 in Hyderabad site. The system has got 2 versamax...
6,288
When I want to connect to another computer that has Proficy projects running, an error meassage appears: "You don't have correct OS rights"...
3,495
Dear All, I am not getting historical trends on my ciplicity project. The points are already added in log data base table of Cimplicity. I am...
1,692
