problem with cimplicity 7.5 on modbus.
Apr 2006
pune
18
Hi
I have problem with cimplicity 7.5 can any buddy help me regarding this.
Actually I am using a cimplicity 7.5 as a SCADA and Delta PLC. The communication between PLC and SCADA is on Modbus. I got a modbus address for Delta Plc as follows
1) Output Coil Y0 - Start from 01281
2) Input X0 – Start from 11025
3) Data Register D0 – Start fro 44097
4) Memory Register M0 – Start from 02049
5) Timer bit T0 – Start from 01537
6) Timer Word T0 – Start from 41537
Now I check all these data on modscan software its coming correctly. But on Cimplicity output coil, input register and data register is showing correctly but whenever I added the memory register or timer bit not timer word ( Its actual / accumulator value of timer) my modbus communication fails. Its shows the device is down.
Thanks and Regards
Shailesh
After changing a windows password of the session where we are running a cimplicity project we are no more able to write values to the PLC. In the...
1,563
Hi All in table logging attribute tab i checked for on digital point high for virtual point. but when i change this point from 0 to 1 no data is...
2,264
Dear All, i am facing one Ethernet communication problem with versamax system and cimplicity 7.0 in Hyderabad site. The system has got 2 versamax...
6,288
When I want to connect to another computer that has Proficy projects running, an error meassage appears: "You don't have correct OS rights"...
3,495
Dear All, I am not getting historical trends on my ciplicity project. The points are already added in log data base table of Cimplicity. I am...
1,692
