Cimplicity redundancy server
Nov 2009
India
116
Hi
I have cimplicity configuration in the existing plant.
Server 1 and server 2 where the cimplicity is running.
Viewer 1 and Viewer 2 which is under the each server respectively.
They made the object redundant servers. Currently server 1 is master and server 2 is slave.
Now i need to develop a new screen. My doubts are...
1. The object redundant server is only for database redundancy or if i develop a new screen will it automatically update on other server.
2. How about viewer system, what will be response of viewer system for the change in servers.
I need to update the changes without stopping the runtime. Kindly suggest me.
Make the new screen and put in projectfile/screens where the gef file is stored. The points for the screen get updated by which server is in control.
If you did not make any new points, then it will show up in new project. The viewers point to screens in project folder where GEF file is. Remember you will have to make button to call this new screen.
I have a Cimplicity Redundant Application. But when I start Secondary Server from Primary Server, it gives an error' unable to start the project...
1,886
Hi everyone, I have a problem, i want to know the channel status in server redundacy with cable redundacy setup , on Cimplicity v10. I tried to...
1,674
when I try to open an application of GE Cimplicity HMI (developed in some other system and I don't know the specs of that syatem, i only know that...
5,124
Hello, I have the following problem: My costumer have a system configured as follows: - Two set`s of 90-30 controller + IO's. - Engineering...
6,691
177
