Cable redundancy status Cimplicity
ACM123
Feb 2020
Stg
Hi everyone,
I have a problem, i want to know the channel status in server redundacy with cable redundacy setup , on Cimplicity v10. I tried to use the "IP status API" but but it does not signal the specific error of the channel.
Any of you guys know how to get the channel status between servers and clients?
Ok here is the problem we have a Siemens DP PLC (Master) and RIO ( slave) at the end of a Fiber Cable that runs through a Slip ring via OLMs...
488
hi all, Please refer to the system configuration. When the Fiber optics line shown in black circles was removed from the network the redundancy...
1,465
Is the of Cable redundancy ( i.e RS-485 Communiation cable) on PROFIBUS been implemented ? Does in achieve the purpose of HOT STANDBY in case of...
4,801
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
98
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
246
