Profibus DB - Cable Redundancy
mad4x4
Mar 2009
ST CYrus
363
Ok here is the problem we have a Siemens DP PLC (Master) and RIO ( slave) at the end of a Fiber Cable that runs through a Slip ring via OLMs
What we want to do is provide provide Cable redundancy to this set up so that the primary route is Fiber through the slip ring with the back up route as a WIRELESS dateable PB link. What we want is a method of fail over so if the fiber fails we can fail over to the WIFI, but we also want diagnostics on the WIFI to prove the "backup" line is good.
Thought about using a PRS ( https://se.profibus.com/produkter/prs-profibus-dp-redundancy-switch but that seems to be for 2 masters.... :(
Here is a "Simple Diagram" of what we want to Achivie
Code:
[FONT="Courier New"]:...............:                              :        :
:               :...........f..................:   SR   :...f....
: siemens       :                                               :................:   IO         :
: (master)      :          .........                  ........  :                :              :
:               :          :  DE   :                  : DE   :
KEY
DE = DataEagle (CU)
SR=  Slip Ring (Fiber)
IO=   Remote IO
f = Fiber OLM connection
[/FONT]
Is the of Cable redundancy ( i.e RS-485 Communiation cable) on PROFIBUS been implemented ? Does in achieve the purpose of HOT STANDBY in case of...
4,801
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
321
Hello everyone, friends. We have a machine where our main CPU is a Siemens S7-300, but with different makes and models of drivers, and modules...
18
3,773
Hello guys, I need your help regarding the proper termination of Profibus cables. I now that in theory in order to minimize the noise and to...
3,621
Dear All, I want to know, due to aging, temperature and humidity present in the room, the power cables got hard. This hardening does effect the...
1,634
